Expansion tank / reservoir coolant hose
I have some experience with this particular hose.
My vehicle is a 2002 Jetta/Bora MkIV ALH 5 speed, wagon, now about 230k miles on it.
Several years back, it was spewing hot coolant (mist) at the "pipe" connection
which I guess comes out of the " Coolant Line "; the other end of this very long hose is the Lower port of the coolant expansion reservoir (the plastic globe that you can see through, until it gets very dirty).
I mean, you hear this hissing sound as you're trying to determine why the coolant level in the reservoir has been bottoming out. The escape of coolant gets worse until you zero in on the problem.
To keep my vehicle running, I cut off the last couple of inches of that hose, and put one of those worm-gear stainless steel hose clamps on it, cinched it up and carried on. Until such a time as I could replace the hose with a fresh one.
But I wondered about this issue ... if the pipe is so hot, and the hose can fail like this, should it not afflict a lot of TDI owners ?
Now, several years later (summer of 2013) I have the vehicle running while driving up in the mountains. Doing some parking maneuvers somewhere, I notice all of this fluid coming from my car and staining the pavement. Oh no, I think, my VE pump fuel leak ( the head gasket, AGAIN !! ) is getting really really bad. But wait, this isn't fuel. It's coolant.
I open the hood and hisssss ... it's coming from the same damned hose, i.e. my 2nd hose failed in the same way. I took my pocket knife, chopped off the bad end of the hose again, shoved it back onto the pipe, and cinched up the hose clamp (the screw adjuster type) which I'm still reusing.
I have to buy this hose again, and I think the p/n 1J0121109C is correct for my vehicle.
EDIT: IDParts.com offers this ( p/n 1J0121109C ) made by Rein Automotive.
I've now been driving for a couple of months w/ the shortened hose in there.
I'm wondering whether using these worm-gear hose clamps hastens hose failure.
I mean, the original spring clamps are said to be compliant, i.e. they're good in terms of allowing thermal expansion. Anyway, the damned hose failed either way; the original one had the original factory spring clamp on it at first. I may try to get the correct size of spring clamp and put one on there this time.
While I was fighting with this, I was looking in the coolant reservoir and was disappointed to find that a lot of the translucent plastic features of its interior are floating around ... they became eaten away, after all those years of hot expanded coolant moving around in there.
I mean, this thing is pretty shot.
I think that p/n 1J0121407F must be the right reservoir for my vehicle. Something else I have to buy !
EDIT: IDParts.com offers these reservoir part numbers:
1J0121403B ( made by Meyle )
1J0121407F ( made by "OEM VW" )
Tank Cap (should buy that too, in theory) ... 1J0121321B ( made by CRP )
Larry
P.S. For convenience, instead of ordering from other online stores ( this time, IDParts had something that I wanted in particular )
Final EDIT: I ordered all of my stuff from IDParts but instead of buying a new reservoir cap, I bought just the "Coolant Reservoir Cap Seal" which is p/n
1H0121687A
