Old April 26th, 2010, 12:11   #1
belome
Fuel Economy: 47'ish
Default Help troubleshooting 12 volt power outlet.
My 2002 Jetta has no power at the 'in cabin' 12 volt power outlet. The manual made it sound like its on the same fuse as the radio. The radio works. Also, the 'in trunk' power outlet also works.
Does anyone know what fuse this is or what else is on the same circuit? I'm assuming that if its not a fuse I'll end up pulling the dash apart and that doesn't sound like a lot of fun.
Any guidance would be appreciated.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old April 26th, 2010, 12:30   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
try #41
Old April 26th, 2010, 12:42   #3
belome
Thanks Bob I'll give it a look tonight.
Old April 26th, 2010, 13:42   #4
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
Originally Posted by belome
(snip) Any guidance would be appreciated.
__. You could do what I did -- take the penny that had fallen into the socket out, then change the fuse. (Seriously, there are lots of little things that can be affecting this. Have a good look at the socket - and on some cars, you can see the back side of the socket and thus the wiring connections by taking out the ashtray; these connections often get knocked off or loosened. But i'm guessing a fuse.)
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06; 130K mi in 4 1/2 years/~57 MPG lifetime); New car, '03 Jetta Wagon, CAT filter, .681 top gear, 350K mi. in 11 1/2 yr, ~52.
mrGutWrench is offline   Reply With Quote
Old April 26th, 2010, 14:12   #5
belome
Hey, I didn't think about taking out the ashtray. Thanks for the heads up on that.
Page generated in 0.13986 seconds with 10 queries
[Output: 64.43 Kb. compressed to 56.46 Kb. by saving 7.98 Kb. (12.38%)]
