Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old August 30th, 2007, 04:12   #1
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Default 12 volt power sorce not working
My 12 volt power sorce is not working , fuse is good . Any suggestions ?
2K jetta gl tdi 5spd 401k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old August 31st, 2007, 09:12   #2
Cabrales
Fuel Economy: 52/42/39
When you say "fuse is good" does it mean you changed it or tested it? Sometimes they look good visually but are still blown. If you find out the fuse is blown, check for foreign objects inside the socket itself. Mine blew the fuse a couple times until I figured out a penny had fallen in the socket and was causing it to short circuit.
2003 Jetta Wagon TDI - Laurel, MD
Cabrales is offline   Reply With Quote
Page generated in 0.13320 seconds with 10 queries
[Output: 48.36 Kb. compressed to 44.32 Kb. by saving 4.04 Kb. (8.36%)]
