dieselg33k
It has been a long time since I have been on these forums .
I have been having trouble lately with starting the car . It is getting worse .
I did the whole Timing belt ,wp, idler ,tensioner re+re after a near disaster 20,000 kms ago( may 2011) . I hit a bump and the tensioner ( weak ) dropped out and allowed the belt to skip one tooth. No start , but no damage either . This is my assumption based on what I saw when I opened up the timing cover .
Other details , the temp gauge will intermitantly drop out to "cold" stay off for 5 mins then snap back to normal . I can't find where the little bstrd is though.
All the glow plugs were replaced december 2010 about 35,000kms ago.
Now 9 times out of 10 when I turn the key the glow plugs will only turn on for a fraction of a second . The car will crank and crank and blow white unburnt fuel out the pipe. It takes 20 cycles of the key and 60 seconds of cranking to get it to finally catch and stay running.
This is becoming an issue , an embarassing smoky issue.
I humbly beg the gurus here for assistance .
all other mods are in my sig
