Tacoma_TDI
Hi all. I've been hunting for the answer and haven't had any luck (forums and Ross Tech site). I'm planning on further simplifying the harness for my Tacoma ALH swap by removing the ECU control for the coolant glow plugs and engine glow plugs, but I've been told it will throw codes. There are also other codes I will want to disable as they will not pertain to my truck. Does VCDS/VAGCOM permit disabling fault codes using the software? If so, how is this accomplished? I feel like purchasing VCDS is a wise move for such a project rather than having to rely on dealers or shops to do stuff such as setting injector timing etc, and being able to disable DTCs would be a huge bonus. Thanks in advance!
