I used the wiring harness from a 2011 in a 2010 body. Added a DPF delete and Malone Tune I used the 2010 ECU and the rest of the components from the 2011. I used the 2010 ECU to keep the VIN and original mileage.
I received the ECU back after the tune and the car would only run with the key in the start position and had the Immobilizer Active message. I returned the ECU to have the immobilizer deleted and recoded for a manual transmission but it turns out they can't delete the immobilizer from the ECU.
I thought I could install the 2010 parts (ignition, immobilizer and cluster and I would be good to go but it would appear the ignition immobilizer was changed and relocated from 2010 to 2011. I haven't seen pictures of the 2011 ignition immobilizer but I couldn't find one that was similar to the one I found on the 2010. I am at a dead end unless I can have the tune transferred to the 2011 ECU.
Can anyone confirm the difference in the ignition immobilizer between the 2010 and 2011 model years?
OK, I am little lost here.
I can fix this but I need to know what did you do and what car and year has what parts?
What is year is the car that you working on?
And what did you put in that car (What parts, Cluster Keys and ECU )?
BTW , Ignition switch has nothing to do with Immobilizer.
Cluster has built in Immobilizer and ECU has Immobilizer.
