Analogeezer
We did the problem was the ambient temp of the seats inside the car was already pretty high, earlier they had tested it by letting it idle in the parking lot on a 95 degree day and feeling both seats and thinking they were equally hot.I would have driven the tech around. Obviously, his weight is greater than yours.
I would also suggest that they measure amp draw accross the hot wire while you are driving it. They can tap into it, run leads over to the passenger side, and monitor it from there. If it is on, it will show amp draw.
Donald
I think what is going on is the seat is not fully "on" to the first setting but on enough to be noticeable, but it's not going to take the seat past the ambient temp just sitting in the sun.
I plan on testing it at night this weekend, we are supposed to get some 60ish degree weather at night and that should make a difference.
As far as my body heat warming it up to 100 degrees, 98.7 is your INTERNAL temp, your skin is not that warm plus sitting on a car seat wearing clothes, with air space, etc. a body is not going to warm a seat up to the kind of level I am talking about.
The one day I went out with my wife in the car, her sitting in it for 10 - 15 minutes took the seat temp up barely 4 degrees (ambient was in the upper 70's, it was 82 when she got out of the car), well below 100 degrees.
The other thing going on is you know the space between your thighs? Where you don't have your legs sitting on the seat?
That part of the seat gets as hot as the rest of the seat I am sitting on.
Analogeezer
