MKT
I went in for my 30K service today, just a few miles early as I am taking off on a driving vacation. At check in I asked if they would check the ash load on my DPF, they noted the request on the work order.
I have a little under 30K on the JSW after 9 months and 2 days of ownership. I drive a lot of highway miles and run 4 ounces of PS (Silver bottle) each fill up. There has been a lot of discussion here about whether PS, or any additive might be harmful to one's DPF. When they were finished servicing the wagen the advisor handed me a screen print from the ash load test. Almost 30K miles and I have a total load of 18.0 ml of ash and the printout reflects the maximum ash load is 175.0 ml.
At this rate, it appears I can, in theory, go to nearly 300,000 miles before the DPF is at the maximum load based off the amount of load I have.
The screen print also states that it will be necessary to replace the DPF in 157,000 km, or converted to miles 97,555 mi. Their system is clearly set to recommend replacement at 120K miles/ 200K km. At the rate I am currently producing ash I should still be below 100 ml ash when I reach 120K miles.
