Old September 29th, 2017, 18:08   #1
farmerx
Default 2005 Passat Reverse Quit (kind of)
My 16 year old daughter is driving our 2005 passat with 214000 miles on it. Today when you put it in reverse it will engage till you step on the throttle then it disengages. when the car drops down to idle again it clunks back in. This happened with no warning. The TCM is a little wet on the outside and the wires going to it are wet. If i unplug the TCM and put the car into reverse it goes in fine but has no forward gears. I think it is electrical but not sure. Any ideas? Thanks Jeff
farmerx is offline   Reply With Quote
Old October 1st, 2017, 15:49   #2
imo000
imo000's Avatar
Fuel Economy: Good enough
Hook up a scanner and look at the trouble codes.
imo000 is offline   Reply With Quote
Old October 5th, 2017, 18:15   #3
Brian's96TDIPASSAT
sounds like the D drum quit
Brian's96TDIPASSAT is offline   Reply With Quote
2005 TDI quit with no signs? Please help. munderhill VW MKV-A5 Golf/Jettas 17 February 15th, 2012 10:17
2005 Passat Clunk when starting to move in Reverse slanted VW B5 Passat TDIs 8 September 6th, 2011 14:48
2005 Passat TDI stalls in reverse on cold start EDT TDI VW B5 Passat TDIs 4 August 3rd, 2009 09:52
2005 Passat TDI stalls in reverse on cold start EDT TDI VW B5 Passat TDIs 0 July 20th, 2009 20:18
2005 Passat TDI always stalls in reverse on cold start EDT TDI TDI 101 8 July 20th, 2009 20:10
Page generated in 0.12477 seconds with 11 queries
[Output: 56.69 Kb. compressed to 51.53 Kb. by saving 5.17 Kb. (9.12%)]
