Old December 16th, 2013, 10:00   #1
KGoodale13
Exclamation Some kind of leak on a 2004 Passat TDI
I pulled my car (2004 Passat TDI) into the garage last night and this morning I noticed a few drops of what looks like oil, I'm not really sure what it is because its not under the oil pan and was wondering if anyone on here knew what it might be.
This is a picture of directly above the leak.
And this is a picture of the oil looking fluid that dripped out, This is on the passenger side and about a foot from the front of the car and a foot from the passenger side.
Thanks for any help you guys can give me, Its greatly appreciated!
KGoodale13 is offline   Reply With Quote
Old December 16th, 2013, 10:45   #2
LNXGUY
LNXGUY's Avatar
Oil inside the IC pipes is leaking out. Completely normal for oil being inside, not uncommon.
Bill
LNXGUY is offline   Reply With Quote
Old December 16th, 2013, 11:24   #3
KGoodale13
Oh okay awesome.
Thanks man
Old December 16th, 2013, 11:38   #4
1854sailor
Resident Curmudgeon
1854sailor's Avatar
How many miles on the car? It looks like the turbo outlet hose has leaking seals, or maybe a hole where it rubs on a wire harness. Pretty common on these beasts.
-George Bernard Shaw
Old December 16th, 2013, 12:01   #5
Dodoma
How do you fix this leak?
Dodoma is offline   Reply With Quote
Old December 16th, 2013, 13:33   #6
KGoodale13
It's got 117,000 on it. Should I get that looked at?
Old December 16th, 2013, 14:19   #7
1854sailor
Resident Curmudgeon
1854sailor's Avatar
If it is the seals, replace them...and the worn clips. If it is the hose it needs to be replaced; it can't really be patched. The good news is that the price on this hose has really come down in the last year. Used to be ~$300 and I last saw it for a little over $100. Guess who bought one at the old price?
Old December 16th, 2013, 14:20   #8
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Definitely. Where in NE are you?
Old December 17th, 2013, 04:54   #9
KGoodale13
Maine
Old December 17th, 2013, 07:26   #10
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Herm is in Richmond; he's a TDI Guru. HermTDI@Yahoo.com
2004 b5 passat coolant leak ???? automan tdi VW B5 Passat TDIs 10 June 1st, 2012 09:47
What kind of MPGs can I expect with a 2012 passat, roof rack and 5 passengers clydesdale6 TDI Fuel Economy 16 March 7th, 2012 13:08
what kind of fluids 96 passat tdi takes? gavros777 TDI 101 5 November 2nd, 2009 17:51
97 passat tdi what kind of oil? sooprdv TDI 101 1 November 26th, 2002 20:05
pics of my one of a kind Passat Normand Passat TDI Picture Gallery 6 July 26th, 2001 09:07
Page generated in 0.15634 seconds with 11 queries
[Output: 94.58 Kb. compressed to 80.13 Kb. by saving 14.44 Kb. (15.27%)]
