Old August 7th, 2011, 08:51   #1
theflyingturtle
Default Poor fueling when cold? Cold-blooded?
You simply cannot be more newb than I! I dare you. My wife and I are the proud owners of a new TDI Sportwagen and so far we LOVE it! Where have turbocharged diesels been all my life? It is the first "driver's car" I have ever had. Right now we are overwhelmed at all the info regarding VW TDIs and we can see the learning curve is very steep at first. So far everything has been running smoothly but I have noticed that when the car is first started up and driven it surges and hesitates, if that is an apt description. Perhaps shuddering is a better word. Like a poorly jetted motorcycle with a tight spot in the drive chain. Sport mode makes it a little better due to the higher rpms but in reading this site I have not heard anyone mention this so I thought I should ask. Thanks.
theflyingturtle is offline   Reply With Quote
Old August 7th, 2011, 10:47   #2
TDiSkater
Fuel Economy: 35 Winter/41 Summer
Actually lots of cold engine performance posts and threads on topic. Assuming it is what a number of us experience, you'll figure out how to get it going with minimum bucking. It was actually my newbie fear on this issue that I found TDI club.
I have DSG tranny also and I drive it in D until I get my first shift, then I drop it to S and run in up to 2500+ RPMs for the first mile. Drop it back to drive and motor on. From what I've read, particularly some posts from Oilhammer, there are a number of engine adjustments and flaps that have to set. Which is what is suspected as the cause of this behavior. Mine has done this from day one and it's not a biggie. I did have dealer check early on and they said normal (at least "VW" normal )
Some report DSG issues when cold, I don't seem to have that as I can tell, but advice that seems to work for them is to not immediately put foot from brake to accelerator (2 second pause at a light or stop). Something about the computer sending a clutch command.
Oh, one other suggestion. Try to run up some RPMs before stopping. I park in a lot at work with several close stop signs. I usually run my car around the small lot before hitting those signs. Takes 20 seconds and I experience very little bucking.
VW-OEM European Steel Skidplate | 35% LLumar Tint all around | Pano Sunroof | ScanGauge II | WeatherTech Weatherflectors and Digital Fit Floorliners l Faux TDI Mirror Etching l RGM Bumper Guard | Conti PureContact | Non-OEM Aspherical Mirrors - $3 Blind Spot Mirror | 70,000 miles |
TDiSkater is offline   Reply With Quote
Old August 7th, 2011, 11:17   #3
theflyingturtle
All is well then. Thanks so much for the reply.
Old August 7th, 2011, 11:31   #4
Mike in Anchorage
Mike in Anchorage's Avatar
You'll see increasingly better running and lower fuel usage as it breaks in. There is a breakin procedure posted somewhere on the 101 forum that gives good info. Welcome & check back often.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Poor Acceleration When Cold bradleyj TDI 101 1 February 10th, 2014 16:04
running cold and poor starting whiterabbit7 TDI 101 14 May 11th, 2009 07:14
Very poor idle on COLD starts only! please help! 02PSDV8 TDI 101 2 September 3rd, 2005 09:55
Help for poor milage during winter cold ?? AndyBees TDI Fuel Economy 17 February 17th, 2005 10:55
My poor, cold dub kidkoala VW MKIII-A3/B4 TDIs 13 January 16th, 2004 21:27
Page generated in 0.14755 seconds with 11 queries
[Output: 64.94 Kb. compressed to 58.21 Kb. by saving 6.73 Kb. (10.37%)]
