Hey, I'm Scott, new to the forum. I've got an 05 Jetta TDI with the BEW motor. 240k miles or so. I've owned it for about 2 years with almost no problems. I was recently driving home from work and the car randomly died. No loud noises or anything, or at least not louder than my music. Couldn't get it to restart. I always go to the cheap fuel station so it runs a B20 biodiesel blend. Figured I needed to do the fuel filter. Changed that out and got it reprimed and still no start. I have the glow plug light come on, so not a relay 109 issue. I've got a working lift pump.
Just last night I was trying to get it to fire and it started cranking really fast but sounded like i had no compression this time. I have now pulled the timing belt cover and it looks good and feels tight. The flexplate is spining with the starter, but not the timing belt and gears. What has failed?
What should I be looking for? I've read about people shredding teeth off belts and then they get this problem. Maybe i did and i just can't see where. The belt is tight and I can't get it to spin freely.
Thanks in advance.
Thanks in advance.
