Old July 15th, 2012, 12:37   #1
bikerboyriley
bikerboyriley's Avatar
Fuel Economy: 46 mpg
Default which rear axle beam bushings to go with?
There seems to be quite a few options, I'm looking for the best option! What do you guys recommend ? for a mk4 golf.
and where should I order them from? idparts?bora?ecs?
2001 2 door alh tdi. Ventectomy, ccv mod, Aero stainless muffler, FMIC, OMI, Street toys gt1856 hybrid, 2.5'' downpipe, PP764, 11mm IP, In tank lift pump, 3barmap, arp headstuds, southbend endurance stage 2 clutch,fuel cooler, mcnally boost/egt gauge, dieselgeek shifter linkage, malone stage 5, ARP headstuds, Koni fsd's
bikerboyriley is offline   Reply With Quote
Old July 15th, 2012, 13:10   #2
03Springer
03Springer's Avatar
Fuel Economy: Avg 50
Do a search here and you will find many different opinions on upgraded (Seat Cupra) etc. or the stock bushings. From reading different threads here I have seen some people disapponted with the upgraded ones, two stiff, makes noise, rides rougher...... The stock replacememt ones should be fine. Your pick on which vendor, the two you have named are both top notch!
03Springer is offline   Reply With Quote
Old July 16th, 2012, 17:56   #3
mlemorie
TDI(s): 2004 Jetta
Fuel Economy: Avg: 43-44
Im waiting on my cupra ones from boraparts, wish I could give you an opinion on them. They were back ordered when I ordered them and I think they are still having trouble getting their order filled.
I have VCDS and plenty of tools.
mlemorie is offline   Reply With Quote
Old July 16th, 2012, 18:10   #4
davebugs
I get OEM or from Bora myself. I know folks get them from Idparts as well. I just happen to get some gasser stuff from Bora as well so other than a skid plate Bora or Metalman is who I've dealt with in the past. Actually I've purchased timing belt kits from DG, Metalman, and Bora. All are excellent folks and I hear good things about Idparts. All the vendors here seem decent.
I just had a set of the "upgrade" ones from Bora to make sure they'd work with my tool.
Frankly I think they may be too stiff for me.
As a comaprison I did the upgraded Audi TT LCA's and with my summer 17's they are a bit rough. Wish I would have gotten stock.
If your bushings are shot replacement will make a major difference. I'm not sure about an upgraded part for this application - for me. Especially with a low profile tire as far as ride quality.
davebugs is offline   Reply With Quote
Rear axle beam bushings, Need help Rob02f350 TDI 101 15 April 3rd, 2011 16:53
Rear Axle Beam/Bushings question rampage VW MKIII-A3/B4 TDIs 4 March 26th, 2011 11:07
Anyone replace the rear axle beam bushings in a MKIV? DannyboyUpstate TDI 101 5 March 1st, 2007 19:58
Rear Axle Beam Bushings reiddo1 Upgrades (non TDI Engine related) 2 August 14th, 2005 19:25
Rear Axle Beam Bushings tdiflyer VW MKIV-A4 TDIs (VE and PD) 3 May 16th, 2004 20:46
Page generated in 0.08764 seconds with 11 queries
[Output: 63.95 Kb. compressed to 57.33 Kb. by saving 6.62 Kb. (10.35%)]
