Old May 8th, 2011, 15:04   #1
euphoria18_79
Default Swapping seats - 2000 Jetta VR6 Leather into 2001 Jetta TDI Cloth -UPDATE
I am not very good with vehicles, and have done numerous searches online, but not sure what to do.
I drive a 2001 Jetta TDI that came with the cloth package.
I purchased a wrecked 2000 Jetta VR6 GLS with the leather package
I have swapped all the door panels, but am now working on the seats. I have taken the front leather seats out of the VR6, and have taken the passenger side out of the TDi. I noticed that there is a black, flat connector in the TDI that is not part of the VR6. The drivers side appears to have 2 different connectors.
so, can i do this? or what do i need to do?
Thanks everyone
Chris
Just to add, both seats are heated, neither have power.
euphoria18_79 is offline   Reply With Quote
Old May 8th, 2011, 15:51   #2
CGDoig
CGDoig's Avatar
Fuel Economy: 40 mpg avg, 50 best
I think you'll have to figure out which wire does what and splice the old connector onto the new seats.
2005 GLS || Malone Stage 5 || VNT 17/22 || PD130 Injectors || Eurojet FMIC
2.5" TT Downpipe / 2.5" Back || Koni FSD's || Eibach Pro-kits || Sb Stage 3
CGDoig is offline   Reply With Quote
Old May 9th, 2011, 05:53   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
You need to tell us how many wires are in that flat connector and what color the insulating jackets on each of those wires are.
They should be plug & play. The driver's seat does have an additional connector from the seatbelt buckle that the passenger's side does not have. Be sure you aren't comparing the left of one seat and the right of the other.
At worst, swap the cushions and skins. I just finished re-doing a 2 door GL Golf with a pair of heated leather GLX Jetta leathers. I kept the 2 door seat frames for their lift and tip movement for rear seat access.
Svante Arrhenius 1896
Old May 10th, 2011, 04:55   #4
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
May I suggest:
1. Lets see some pictures.
2. Swap the leather onto the cloth frames and thus no splicing required! It's not hard to do.
Good luck.
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old May 16th, 2011, 22:49   #5
LNXGUY
LNXGUY's Avatar
Originally Posted by thebigarniedog View Post
May I suggest:
Good luck.
Waste of time. Swapping the connectors is a very simple task.. Way easier then ripping the seats apart.
Lots of info over on Vortex.
http://forums.vwvortex.com/showthread.php?2547339
Here's a PDF with wiring schematics...
http://borasport.com/Images/Recaro_S...structions.pdf
Bill
LNXGUY is offline   Reply With Quote
Old June 18th, 2011, 19:13   #6
euphoria18_79
Sorry had other issues with the car that i had to do first. Now back to getting these seats installed. None of the clips match, as it looks like the clips changed between 2000 and 2001. So here is what i have. I am putting the leather seats in and taking the cloth seats out.
So here is the wires for the leather seats:
Drivers Side
Black Plug - brown wire, yellow wire
Green Plug - black/yellow wire, black/white wire, brown wire, thick brown wire
purple/yellow plug - brown wire, white wire, green wire
Passenger side
purple/yellow plug - brown wire, white wire, blue wire
this is what my car currently has for the cloth seats
Drivers Side
Yellow Plug - red wire, brown wire, yellow wire, brown wire
Green Plug - Black/yellow wire, black/white wire, brown wire, thick brown wire
Passenger side
black plug - purple wire, brown wire
yellow plug - white wire, blue wire, brown wire
http://s138.photobucket.com/albums/q252/euphoria18_79/
That is a link to photos.
Old June 20th, 2011, 23:04   #7
euphoria18_79
Or does anyone have a suggestion / is there an adapter that can be purchased?
Old June 21st, 2011, 23:46   #8
euphoria18_79
Checked the vwvortex thread, but still confused.
Old June 22nd, 2011, 14:08   #9
kiwibru
kiwibru's Avatar
This is not a hard thing to do. All you need to do is systematically trace, cut and re-wire the male connectors from your newer car seats over to the existing car wiring harness. The newer seats will have two seat belt wires, the older seat will have one (drivers side only). You can un-bolt the actual seat belt cable with wire and swap it over to the new seat. 10mm triple point as I remember...
The wires are similar enough in color (look for same color, then via process of elimination and position on old / new connectors move the needed male connectors from the new seats to the car harness. Hopefully you have all the connectors (male/female) on the new seats. Just ID, cut, splice and add a bit of solder, cover with electrical tape and if you are really concerned some shrink tubing slid on before the soldering, then heated to shrink over the soldered / wrapped wires.
Jeez, I think the description is harder than the actual doing! Anyway you can do it, just be methodical!
Silver Golf 2k, RC4, many supporting mods...Red RTDI gone but never forgotten...it lives on with another owner!
San Juan Is. WA.
kiwibru is offline   Reply With Quote
WTT: 01 Jetta Leather Heated Seats traded for Cloth Seats FREE+SWAP Madison, WI jasonvictory86 Private TDI Items for Sale/Wanted 5 December 5th, 2010 13:15
FS: 2001 Jetta TDi 5SP, Leather, Heated Seats kl8ton TDI Cars for Sale/Wanted 13 April 17th, 2007 14:41
FS - 2001 Jetta Grey Cloth Seats RunningSnail Private TDI Items for Sale/Wanted 2 March 28th, 2007 19:04
swapping leather seats for cloth? brotha bran VW MKIV-A4 TDIs (VE and PD) 12 February 18th, 2007 12:35
Blk Leather Seats (Jetta/4dr Golf) with Air Bags $300+ your heated cloth Seats G60ING Private TDI Items for Sale/Wanted 9 October 12th, 2006 08:41
Page generated in 0.15517 seconds with 11 queries
[Output: 94.55 Kb. compressed to 80.76 Kb. by saving 13.79 Kb. (14.58%)]
