lilsmoker
Just recently the warning display started flashing the coolant temp lite, after starting it up cold( for so.cal.). It stays on and keeps flashing even when the engine is warn or up to temp. The car doesn't overheat or run warm according to the temp. gauge when driving. Its normal commute is about 17 miles one way against traffic flow so its doing about 50 mph most of the trip. Also the coolant level is correct in the bottle. I'm thinking bad temp. or coolant level sensor. Any ideas would greatly be appreciated.
