Why do you need to "see" the tunes?So I can't see the tunes on flashzilla when on my pc.
Only when plugged into car I see them.
Or am I missing something on the pc?
I just wanted to see what was installed.Why do you need to "see" the tunes?
Was just looking for what tunes are installed.PC have a “hide file” feature that is a pain sometimes to disable to see what’s really in the file. Most likely if you do get it open you will find just coding.
Not quite sure what you're trying to do? Download is to download data from the device that was pulled off a car, it won't download the tunes loaded on the device just the read from the car, upload would be loading a file sent. The file will been named for what tune it is, the device will tell you if that file uploaded, then you can check them via obd before flashing to the car. The powergate devices don't always show files loaded on the tool, it will also say "vin not locked" even if it is, Italian software and has the odd quirk.
