Lessfilling_runsgreat
- Joined
- May 9, 2000
- Location
- Walnut Creek, CA 94598
- TDI
- 1998 Jetta - RIP (Rest In Pieces); 2003 Jetta TDI GLS
I have some weirdo codes going on in MKIV Jetta TDI. I suspected the ECU was faulty so I got an upgraded (stage 1.5 tune, IMMO and EGR delete) from Jeff Stevenson. I also have a sport cluster with full color Audi display MFA in it. The MFA won't give me a torque reading or boost pressure. This happens with both ECUs and new OEM MFA style wiper stalks installed.
Here's my VCDS log:
Friday,29,March,2019,13:46:56:41483
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 3VWSP69M33M142094 License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSP69M33M142094 Mileage: 332000km-206295miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G000SG 4102
Coding: 00002
Shop #: WSC 00066
VCID: 57B7894AB5AF6FF2CC-4B18
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 00066 000 00000
VCID: 346D1EC6549964EA09-513C
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 2757F98AC54F1F72BC-5120
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 00066
VCID: 2F6711AAEDBF473274-513C
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
25-10 - Unknown Switch Condition - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 946 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 15232
Shop #: WSC 50403
VCID: 316317D2FB8B51C262-5120
3VWSP69M33M142094 VWZ7Z0B5961688
1 Fault Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 50403
VCID: 70E5D2D6300118CA2D-5102
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 377729CA15EF8FF22C-4B00
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0009
End-------------------------(Elapsed Time: 05:47)--------------------------
I suspect the wiring from the wiper stalk to the cluster or God forbid to my ECU, but I'm not certain. Another strange thing is the intermittent wipers only have one speed regardless of switch position. OEM MFA Stalk has been changed twice. Has anyone run across this before? Does anyone have any ideas where to begin on this?
Thank you.
Here's my VCDS log:
www.Ross-Tech.com
75 76
Coding: 00002
Shop #: WSC 00066
Coding: 0019458
Coding: 12340
Shop #: WSC 00066
Coding: 00118
Shop #: WSC 00066
1 Fault Found:
Coding: 15232
Shop #: WSC 50403
1 Fault Found:
Coding: 00006
Shop #: WSC 50403
Coding: 00258
Shop #: WSC 00066
Thank you.
