Hello peeps!
My fiance was driving our beetle TDI alh 5spd and she suddenly lost boost. Got a check engine light for low boost sporadic . We managed to limp home and started by replacing all of the vacuum lines. That didn't change anything. So then we tried replacing the n75 valve, no luck. Next we decided to go ahead and replace the turbo. (Had 334,000 miles on it). While we were at it we also replaced the vacuum pump and egr valve and fuel filter. However I was stupid and forgot to prime the filter before trying to start it. It took a minute to start but it fired up with a CEL code. 17656 start of injection timing regulation, control deviation sporadic:
It runs and drives fine except no boost until 3000 rpm. Tried deleting code and it immediately popped back up. Where do I go from here?
