hause
Vendor , w/Business number
- Joined
- Nov 12, 2011
- Location
- Charlotte (Noda), NC
- TDI
- MK4 Golf Tdi... all souped up also a MK7 Sportwagen on its way to greatness
https://dieselenvy.com/2019/04/13/2...-6-spd-manual-39k-miles-11-yr-warranty-10995/
3VW3A7AJ8FM342437
2015 Volkswagen Jetta TDI SE
2.0 L CR turbo diesel engine
6 speed manual transmission
BACK-UP CAMERA HEATED SEATS – DRIVER AND PASSENGER SATELLITE RADIO SIRIUS
BLUETOOTH CONNECTIVITY LEATHERETTE SUN ROOF
Needs tires, little bit of rash under front cowl – very nice car overall
Car has no problems, needs nothing, emission fix is completed and comes with warranty as follows:
The warranty period for the “Extended Emissions Warranty” limited
warranty extension shall be the greater of:
11 years or 162,000 miles, whichever occurs first, from
the vehicle’s original in-service date; OR
5 years or 60,000 miles, whichever occurs first, from the
date and mileage of Phase 1 of the emissions modification.
At the time of the subsequent Phase 2 modification, the
extended warranty will be honored for 5 years or 60,000
miles, whichever occurs first, from the date and mileage of
the completion of Phase 2.
The vehicle’s original in-service date is defined as the date the vehicle
was delivered to either the original purchaser or the original lessee; or
if the vehicle was first placed in service as a “demonstrator” or
“company” car, on the date such vehicle was first placed in service.
Parts Covered Under Extended Warranty
The emissions system warranty shall cover the following parts or
systems:
The entire exhaust after treatment system, including the Diesel
Oxidation Catalyst, the Diesel Particulate Filter, the Selective
Catalytic Reduction converter, the dosing injector and other Diesel
Exhaust Fluid system components, the exhaust flap, and all sensors
and actuators
The entire fuel system, including fuel pumps, high pressure fuel rail,
fuel injectors, vibration damper, pressure control valve and all
sensors and actuators
The EGR system, including EGR valves, EGR cooler, EGR filter, EGR
temperature sensor, all related hoses and pipes, and all sensors
and actuators
The turbocharger, including the turbocharger damper
The On-Board Diagnostic (OBD) system, including SCR DEF quality
sensor, and any malfunctions detected by the OBD systems other
than those related to the transmission.
Additionally, the engine long block warranty shall cover the engine
sub-assembly that consists of the assembled block, crankshaft, cylinder
head, camshaft, and valve train
The extended emissions warranty includes parts, labor, and applicable
taxes. The extended emissions warranty shall not void or supersede any
existing warranty. Conflicts concerning the warranty are to be resolved
in favor of the consumer.
More information about your extended emissions warranty coverage is
available at http://www.vwdiesellookup.com
Transferability
This extended emissions warranty is fully transferable to subsequent
owners.
Warranty Notices
All normal warranty provisions remain in effect.
Email with questions, call if you would like to purchase. Serious inquires ONLY!
Matt 704 860 3729 $10995
DIESELENVY.COM
2210 N TRYON ST
CHARLOTTE NC 28206
3VW3A7AJ8FM342437
systems:
and actuators
and actuators
Transferability
owners.
Warranty Notices
DIESELENVY.COM
2210 N TRYON ST
CHARLOTTE NC 28206
