KITEWAGON
We have a recent issue with the infotainment issue in the Touareg. Everything works except for the media button. When the media button is pressed it hangs on the loading screen. When the car is started the CD player module in the glove box makes a clicking noise for a few seconds and then stops. I've done quite a bit of web searching but haven't come up with anything. I'm wondering if this could be as simple as a loose connection somewhere, but I can't even figure out how to get access to the disk drive mechanism.
If anyone has come across this before or has advice on troubleshooting, please let me know. Here is the data from the VCDS scan.
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 D HW: 7P6 035 664 A
Component: H-BN-NA H40 0706
Revision: -------- Serial number: 273EU0DB001561
Coding: 020200050040E1EF41022B0E00000003F00001030000000000
Shop #: WSC 31414 790 00001
VCID: 39792F99B0F66882DA-806C
Subsystem 1 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M7900L72
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
2 Faults Found:
00658 - Control Head
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 160
Time Indication: 15
Freeze Frame:
Voltage: 14.30 V
Bin. Bits: 100
02446 - Disk Drive Mechanical Malfunction
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 118
Mileage: 237118 km
Time Indication: 0
Date: 2019.03.02
Time: 16:54:29
Freeze Frame:
Voltage: 14.10 V
ON Time: 5158 h
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 160
Time Indication: 15
Freeze Frame:
Voltage: 14.30 V
Bin. Bits: 100
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 118
Mileage: 237118 km
Time Indication: 0
Date: 2019.03.02
Time: 16:54:29
Freeze Frame:
Voltage: 14.10 V
ON Time: 5158 h
