Clutched alternator onto 1Z, Wiring?
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
markward
Loxahatchee, Florida
82 Vanagon and 2011 JSW
A picture would help. The blue wire has always been the alternator warning light circuit. The other wire is the "W" terminal and on some models connects to the ECU. It can also be used as a Tach signal in some applications. The B+ wiring is heavy gauge red wire and should not be confusing between Alternators.
ryanp
I'll get a couple tonight, The wires were covered so i might have to do some camera trickery! lol
Ry
ryanp
Here is the old plug, one blue wire and one red/black
New plug, one blue and one blue/black
Is it as obvious as it seems? solid blues connected the same?
slow-moe
Germany
N/A
You`re right. Connect blue wire (D+) on old alternater with solid blue (L) on new one for control light and red/black (DF) to blue/black (DFM) on new one fo ECU. New pulley is 5mm bigger btw.
ryanp
yeah i saw the pulley was bigger! it should have enough slack in the belt!
Thanks so much for the help!
Ryan
