honesttussey
Hi all. I've owned my Jetta MkIV TDI since '03. I've had a myriad of problems. But one problem in particular hasn't been fixed. No one knows what cuases it.
I get a random (once a month to several times a week to several months with out the issue) no start issue. I've had the following components replaced in the last 6 mos
-EGR Valve
-ECM (can you believe it!?)
-Fuel Relay
-Battery
When I insert the key and turn it, for 1 second all the indicators light come on for a brief second EXCEPT for the glow plug light. If I try to start the car the engine turns over and over but doesn't catch. This problem has been with my car since I've owned it. The problem goes away after 5 minutes or longer. Any ideas?
-EGR Valve
-Fuel Relay
-Battery
