Have a friend who keeps blowing headgaskets.
The info.
1.6 block
1.9azz pistons
ARP studs/bolts top and bottom
~3bar of boost
running with standard oem 1z headgasket (3 hole) 1.3mm thick.
head and block is resurfaced.
unknown CR, but need to be lower.
Easy part is just to go 2xOEM 1.3mm headgasket, mabye o-ring the block to keep boost inside.
but will it hold when boost it dialed in (3.5-3.8bar ?
car is only being used as a quartermile toy
Other suggestions ?
The info.
1.6 block
1.9azz pistons
~3bar of boost
Other suggestions ?
