Fastbird
Supposedly the lift pumps aren't supposed to prime when you initially key on (or in my case power on with the start/stop button).
Mine does. I've always heard it but thought it was something else. After priming via VCDS and listening to the pump sound changing as pressure built, I could hear the change when I initially power on too.
Oh and broke a Snap On T20 Torx when opening the fuel filter canister. Yaay. Thankfully I had spares, but it took a bolt out to get the one bolt to loosen.
