ptreads
I bought a 2012 Passat tdi sel automatic transmission with flood damage that had hydrolocked. I was able to get the motor spinning relatively easy but but am worried about water in the transmission fluid. It didn't come with an owners manual and I can't find a check plug anywhere on it. I loosened the bottom drain plug and the transmission fluid came out looking clean. I took the filter off under the battery box and there is visible fluid. Any help or suggestions would be appreciated. Thanks
