annieneff
- Joined
- Jan 13, 2011
- Location
- Seattle
- TDI
- 1983.5 Westfalia tdi (afn), with flipped 5 speed V6 (dvz) transmission
I started another thread about a flipped transmission adapter and swap (here: https://forums.tdiclub.com/showthread.php?t=451265), but that adapter plate swap was an utter failure, so I’m starting a new thread here.
The approach below is wholly new (for me… other people have done it already), and hasn’t been exclusively covered in other threads out there. So. I’m writing it up here.
Tim Shettle said only about 6 people in North America have ordered his plates. This number should be much, much higher; this is absolutely the best engine and transmission combination for these vans, and it’s the lowest cost! If you love you some vanagon, this is THE way to go.
I bought a transmission adapter plate and cv adapters from Tim Shettle for around $550.00 usd. Website here: http://ultimate-engineering.co.uk. The exchange rate is exceptional against the pound right now (March 14th 2016), so if you have any inkling of doing this: do it now!
Along with the adapter plates, I bought a 2000 V6 5 speed (code DVZ) for $230.00. You can probably get one for much less if you’re a little patient and crafty. I got the linkage and shifter along with the transmission—make sure you do too.
Also need a Starter, Flywheel, Pressure plate, and clutch plate. About $500.00 for everything.
So. I’m into it for about $1,250.00 total. One of my original goals was to keep the cost of this reasonable and make it easy enough to accomplish. Of all the options out there (see my other thread for analysis of all the options), I think this one is the most reasonable, and relatively easy to accomplish. Although, I would have like to have kept it close to $500.00 total.
Potential cost savings include only buying the transmission adapter plate (the cv adapters are as much as the plate). That would have knocked around $250.00 off the adapter price. Getting a friend who is in Great Brittan to bring the adapter bits to you, instead of paying for shipping. Making the adapter plate myself. And/or sitting at home and staring at a wall and not doing this insanity in the first place. For convenience, and because I have the $$$ right now, I went the route I did, but it wasn’t without a certain amount of consternation. But my larger point is that it is possible to make this even more affordable. Getting the transmission for free (or close to it) is possible. I’ve seen many manual passats on CL lately for as little as $300.00. just getting the transmission and parting the rest out would make it worth it, and probably then some!
This transmission adapter plate opens a door that a TDI Vanagon needs: now there are reasonable transmission options (both cost, and ideal gearing wise)! I have a DVZ transmission, but I think you could just as easily put the tdi 5, or even tdi 6 speed in there with this adapter plate. I’m not doing that because those are expensive, and I’m not sure they’d be worth the extra money as the gearing might be too low then—but the bigger point is that there are options for transmissions. This has been a big hurdle for me, and I’m sure many others out there.
Below I’ll document how I accomplished my linkage setup, how the installation goes, and then impressions and reports on how it all works. A big thanks to Tim Shettle!
Today, April 15th, I drove the thing for the first time with the new transmission. At 55 mph the rpms were at 2085! It was just dreamy! There was some vibration, especially when I asked for power. I think the axles aren't happy, but all and all I'm extremely happy with the result!
