Depends on if you have a GSW or not, the hatchback has two hitch options that I know about, though same manufacturer, drawtite and hidden hitch.I recall some discussion here last summer about hitches. (And he lack of availability.) Has anyone found a hitch for this car yet?
Most people do not want a Euro hitch...The Westfalia and Bosla make hitches for the MK7 and are available see post above.
I've emailed them as they had a nice JSW setup, nothing right now for the GSWCheck out Torklift Ecohitch.
I'll be going with EcoHitch. I stopped by their shop and the hitch is awesome!The Ecohitch has everything but the weight rating.
I just checked out their site.I'll be going with EcoHitch. I stopped by their shop and the hitch is awesome!
Weight rating was 2000ibs!
By far the nicest hitch I've seen. AND when installed, the cleanest.
How did this go, etrailers has since removed your question because I think they since decided it doesn't fit. I sent mine back without opening the box. Did you get it installed?I just recently got in contact with e-trailers and they told me that the draw-tite part 24925 will fit. So I ordered it and the wiring kit yesterday. I will let you all know how it turns out.
Link to my Q&A:
http://www.etrailer.com/question-119245.html?fb=yes
Seems to bolt directly to the frame so it should be solid. I towed two dirtbikes, tools, fuel and equipment (maybe 600 lbs) on a 550lb 5'x8' TSC trailer 1400+ miles each way from Texas to Michigan and back in my wife's 2009 Jetty wag w/ 2.5 gasser w/5 speed and it did fine both there and back.
I can tell you it fits the standard mk7 golf tdi (installed mine this weekend). Not sure of sportwagen fit, though.How did this go, etrailers has since removed your question because I think they since decided it doesn't fit. I sent mine back without opening the box. Did you get it installed?
Ah yes, thanks for the clarification, sometimes I forget this isn't a wagen specific forum!I can tell you it fits the standard mk7 golf tdi (installed mine this weekend). Not sure of sportwagen fit, though.
funny, the towready web site says the #118646:Just installed HiddenHitch part#60362 and trailer wiring from towready #118646 - plug and play, no cutting of the oem harness.
