Old October 27th, 2003, 11:08   #1
Gilberto
Default Engine Hot Start
Greetings,
i have a A3 TDI and for a long time im getting hard to start it but only when the engine is hot, then last week i unplugged the coolant sensor and then start imediatly.
My question is why if the ambient temp is about 20 C ??
Gilberto is offline   Reply With Quote
Old October 27th, 2003, 20:20   #2
bugginbobb
You need to unhook fuel pump shutoff valve and use vag-comm to measure engine rpm when cranking the starter. You need at least 325-375 rpm for proper warm startup. You either have a weak battery or a weak starter.
bugginbobb is offline   Reply With Quote
Page generated in 0.07766 seconds with 10 queries
[Output: 46.59 Kb. compressed to 42.76 Kb. by saving 3.83 Kb. (8.21%)]
