Lmannyr
So I did an EGR valve and EGR cooler delete (no tune) using the Darkdide Devlpment kit to retain the ASV. In the process, I checked the down pipe gasket. The down pipe gasket showed signs of leakage. Oh well. Reused the gasket since I did not have one on hand and tightened the turbo/DP clamp as much as possible. If it smells again. I'll replace the gasket.
I'm planning on a 2056vk turbo grade kit from Darkside in the next couple months. I'll tune then.
