oilhammer
When people say 'always had a problem' what I hear is the transmission is acting normally, and you do not agree with the way it normally operates. Many newer automatics, expecially ones with 4+ gears like your 09A, will act strange when the ATF is not up to temp. I have never been in ANY computer-controlled VAG automatic that behaves the way I would want it to, that is just the way they are.vwmk4 said:The 0m1 is not the only Vw auto with problems. My 2005 golf has the 5 speed automatic and has always had a problem. This happens before the car is up to operating temperature.
When shifting from third to forth gear there is what the stealer called a RPM flair. It hesitates to shift then when it does there is about a 100 rpm spike as it shifts. they checked it out and there was no stored code so they will not do anything about it.
The service writer and tech. were no help, seems like I'm just SOL.
I bet if you drove an identical car, under identical conditions, you'd find it behaves just the same as yours.
