Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old April 3rd, 2012, 18:42   #1
lazerguy
Fuel Economy: 44 mpg (97 TDI Jetta)
Default M-TDI and Emissions Testing
Hi Volks!
Has anyone here passed Emissions testing with an M-TDI?
I'm very interested in converting to M-TDI, but Canada will soon introduce yearly testing, and that's something I need to consider before taking the plunge.
Would a properly tuned M-TDI have better or worse emissions than the stock TDI?
Thanks!
lazerguy is offline   Reply With Quote
Old April 3rd, 2012, 19:08   #2
golftdi140
Fuel Economy: 35-45 depending on Temp
M-TDI?
Sent from my DROID4 using Tapatalk
golftdi140 is offline   Reply With Quote
Old April 3rd, 2012, 20:42   #3
GoFaster
Moderator at Large
Short form for "mechanical TDI" i.e. a TDI (rotary-pump) engine with the old IDI (mechanically controlled) injector pump, or a hybrid injection pump using a combination of TDI and IDI internal parts so that the electronics are no longer used.
What vehicle are you putting it in, and what engine was that vehicle originally equipped with?
If it is for the vehicle that currently has your '96 IDI engine, that vehicle did not have any electronic engine controls as originally equipped - no OBD-II as originally equipped. Therefore there is nothing to scan and there never was anything to scan. Won't make a difference M-TDI or IDI, same situation. Even if they go to the trouble of checking with VW using the vehicle's VIN, VW will tell them that it originally has no OBD-II.
Emissions-wise, if you get the injection timing in the ballpark and don't go too far overboard with the fuel delivery, it ought to pass any test that an IDI would have been called upon to pass in that same model year.
If you do the job right, the engine will look (almost) the same as the original engine, so no one's the wiser.
If you want to do this to your TDI then the lack of OBD-II on a vehicle that was originally equipped with it could be trouble.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is offline   Reply With Quote
Old April 4th, 2012, 04:17   #4
lazerguy
The M-TDI would be my 97 Jetta TDI (ALH engine) with manual 5-spd.
Old April 4th, 2012, 13:57   #5
GoFaster
Moderator at Large
Off hand, I'd say that's going to get you in trouble, because that car had OBD-II as original equipment.
Brian P.
Old April 4th, 2012, 15:55   #6
lazerguy
Thanks! That's exactly the kind of info I needed. Then I guess my safest bet will be to invest in a good OBD scanner or vag-com, and replace whatever faulty sensors.
Old April 9th, 2012, 09:49   #7
oldpoopie
oldpoopie's Avatar
An mtdi will never run as Efficiently and smoke free as an ecu tuned car at the same power level.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old April 11th, 2012, 10:26   #8
westyman
Karl Mullendore
1987 Westfalia Syncro m-TDI/VNT
1990 Syncro 16" highroof camper, m-TDI project
2004 Passat 4motion wagon 1.8T
www.westyventures.com
westyman is offline   Reply With Quote
Old April 11th, 2012, 14:33   #9
oldpoopie
oldpoopie's Avatar
Originally Posted by westyman View Post
Hey, im not hating on the mtdii, just stating the truth.
Old April 11th, 2012, 14:39   #10
westyman
The truth require evidence, not heresay. Some mTDIs are certainly not set up well; mine are and run as efficient and clean as my Passat TDI.
Karl Mullendore
Old April 11th, 2012, 15:01   #11
oilhammer's Avatar
Fuel Economy: fantastic
Why on Earth would you actually want to step backwards? I can see if the engine was going into something that was not originally a TDI in the first place, but if your '97 Jetta was born a proper TDI, why bother with a good thing? That EDC system is super stupid simple anyways.
www.cardocautomotive.com
Old April 11th, 2012, 18:42   #12
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Saw a MTDI once and was not impressed. Engine being run by a computer is far better than any mechanical means.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old April 11th, 2012, 19:13   #13
westyman
You saw ONE. 'Nuf said. You are clueless as to what else is out there, or perhaps even more importantly - what goes on in ECU-controlled, VE-pump TDIs.
Some of us have far better results than you might imagine. My latest mTDI Syncro Westfalia, for instance, has more power and runs cleaner than my comparable '96 Passat with Alligator chip and PP520's - same engine, same injectors.
Karl Mullendore
Old April 12th, 2012, 00:13   #14
oldpoopie
oldpoopie's Avatar
And you are running a wastegate turbo that cant perform with the fnesse that the vnt can.m
Old April 12th, 2012, 09:08   #15
westyman
You shouldn't make assumptions based on knowing nothing about what I build. FYI, the van mentioned is running a VNT1749.
Karl Mullendore
Nevada- '09+ TDI's exempt for emissions (smog testing) andylyco Mountain/Southwest States 1 August 23rd, 2011 23:48
Use biodiesel before emissions testing? JamesBa TDI (Diesel) Emissions 3 April 14th, 2006 05:59
KY emissions testing? MIA TDI 101 3 September 22nd, 2003 11:40
(5) 02 Golf GLS TDI's Used Only for Emissions Testing Harvieux Private TDI Items for Sale/Wanted 8 November 15th, 2002 07:37
Emissions Testing Bernie VW MKIV-A4 TDIs (VE and PD) 9 June 27th, 2000 01:18
Page generated in 0.15251 seconds with 13 queries
[Output: 128.42 Kb. compressed to 107.11 Kb. by saving 21.32 Kb. (16.60%)]
