skidlid
I just pulled the tranny out and replaced both aluminum cylinders that went bad. One was broke so the clutch pack came apart. I found and accounted for all the chunks and it looked like the filter did it's job. I cleaned, flushed, and resealed the entire unit. Put everything back together and I'm not making boost now.
I'm not nervous about the assembling of the tranny, I've been doing these for quite a few years. Can these two codes be intertwined? Is the lack of boost causing the tranny code as well, or am I just wishing it would be that easy?
I have been having trouble finding a thread with a few pictures on how to test the N75 valve. I'm thinking I could have caused the problem by "disturbing" everything when I removed the tranny. I'm starting to run out of ideas.
I can reset the codes and the limp mode goes away. The tranny starts shifting smooth again but with no boost.
I'm running out of hair!!
