whitedog
Car is a 2001 Passat and the ABS light is on and the brake light flashes. At first, I could not communicate with the ABS controller. New controller and we can communicate, and it's showing an open or short to plus on the Right front speed sensor. I unhooked it and checked resistance and it matches the other side. Beyond that, I don't know how to go about checking these. It's a two wire sensor, so can I watch voltage on the sensor while I spin the wheel?
I did a full scan and a few of the modules showed no communication with the ABS controller. Would the speed sensor cause this?
Lastly, would the Right REAR wheel bearing being bad loose cause this thing to wack out?
