Deebeaux
Vendor , w/Business number
Alright, this weekend I spent most of the time cussing (yeah, in German!) at the PD150 intake swap. Started with a stripped allen head on a manifold bolt and went down from there. (Irwin Bolt-Grip works fantastic for this by the way. Found that hint somewhere on these forums I think.)
The woes started when I realized that with the kit from ryanp you would lose the water/coolant based EGR cooler (not his fault, this is just the way it is, if you're considering a Euro part or 6-speed purchase from him, go for it, awesome guy to deal with, ships everything lightning fast to the States) u'd just have a pipe. This would lead to a less efficient EGR system, longer warm up times, higher intake temps, and I'm guessing loss of fuel economy in certain situtations. All bad for those of us in the quest for better performance AND fuel mileage. (I'm okay with cleaning my intake out every so often using the blow torch & compressed air method to de-soot. My non Diesel friends find it entertaining.)
I accepted that loss and proceeded with the install bypassing the water based EGR cooler and then discovered that you cannot bolt the KermaTDI Old Man Intake (OMI) down in either of it's mount points with the PD150 intake set up as the vacuum actuator is now in the way of the pipe as it's 3/4" or so more toward the driver side (LHD) of the vehicle.
So at this point, now I'm very frustrated.
As it turns out all you need is a 3/4"-13/16" or so spacer (a piece that could easily be laser cut) between the intake manifold and the EGR, and you need to shorten the height of the EGR cooler pipe just a hair (guessing 1/8" or so) to retain the stock ALH coolant/water based EGR cooler. The OMI probably won't bolt up exactly, but extensions could be welded to the existing bracket without issue.
Am I really missing something? Is there a euro EGR system that's better suited for this, or should I just proceed with the making of a spacer to accomplish this goal? Or am I just completely nuts for thinking I can keep EGR with a PD150 intake and add an OMI?
