Hello,
Im bussy with a dual chamber intake mainfold.
My interest in the intake design is to even the air stream to all the cylinders.
and also a wave effect to get a ram in it.
The long runners from the 1Y 450mm is perfect to tdi rpm range.
the things I'm using to built
intake mainfold from a 1.9 D 1Y
alu tube 135mm dia. 350mm long this is the large plenium. approx. 5 L.
tapper alu tube with 10mm gap to fill the large plenium.
https://plus.google.com/u/0/1089173...6100827479703077074&oid=108917392344342499586
after welding and new cam nps stage 2
Im going for a dyno
Im going for a dyno
