Skippy
http://forums.tdiclub.com/showflat.php?Cat=&Number=554483&page=0&view=&sb=5&o=&fpart=1&vc=1
[ QUOTE ]
valois said:
We will be offering a TDI stage 2 (150 hp) and stage 3 (170hp) kit on or about september 1st.
The kit's will contain a larger turbo which has watercooled sleve housing, auxillary oil cooler connected to the oil supply on the turbo, front mounted intercooler, metal intercooler pipes, 2.5 " SS downpipe, heat treated cermachromed exhaust manifold, an adapter pipe with proper EGT port and finally software for 150 hp with assured reliability. 170 hp kits will contain the same items, but the software will be tweaked to provide 170 hp , this level will probably require the user to invest in some raceware head bolts, a solid flywheel, and a sach's power clutch kit. A quaife is also recommended. On both these kits you will be able to use larger injectors reliably, boost pressure on stage 2 will be set at 19 psi continuous. Pricing has not yet been established on the kit, but it will be broken down into components, ie. turbo is $1000.00 Intercooler is $1000. but in kit form there will be a discount, we hope to keep price below $3500.00. There will be 10 kits offered initially, after that it's a matter of ordering it. If you are interested contact me.
[/ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
