nitec
Folks,
I've taken this project as far as I wanted to so it's time to let somebody else enjoy it...
2006 A4 Avant 6spd quattro TDi
https://youtu.be/efAIDWX88oY
Engine:
- BEW PD (04 Jetta) base
- bored out to 2.0 using BHW pistons
- all new crank bearings and seals
- all new timing belt including pulleys and water pump
- T25 8V high flow turbo manifold
- Holset He200 4cm turbo
- EGR/ASV/MAF delete
- Euro BPW A4 ECU, engine harness and accessory bracket
- 4 bar map sensor
- custom turbo back Magnaflow exhaust using high flow diesel cat and muffler
- custom 2 micron CAT fuel filter
- 7V glow plugs
- 22lbs steel single mass flywheel and heavy duty clutch/pressure plate kit
- brand new BHW starter
- brand new engine and transmission mounts
- brand new cam and cam followers
Chassis:
- Bilstein HD shocks (new)
- all new front suspension including all control arms, tie rods, bearings etc
- RS4 rear sway bar
- 6spd manual transmission
- new brakes all around
- 17" BBS wheels with new Firestone Firehawk Indy 500 Oval tires, 17" S4 wheels with Kumho KW22 studded winters and a spare set of 17" AMG converted wheels are included
Engine has reached 10000km since compete rebuild and is well broken in... The cam, cam followers, timing belt and turbo all have less than 2k on them...the car is QC plated and shouldn't need anything for safety. ..tune can be adjusted as per buyer preferences. ..
Msg for more details. ..lots of spare parts available, price is negotiable...I`m sure I`m forgetting tons of stuff...I've got about $30k in this build - would like to see $12.5k CAD (10k USD) for the car
here's the build thread:
http://forums.tdiclub.com/showthread.php?t=436378
Engine:
- 4 bar map sensor
- 7V glow plugs
Chassis:
- RS4 rear sway bar
