andyv
Can anyone tell me what short shifter kit will fit a 2003 VW TDI Jetta Wagon? I already checked dieselgeek.com and can’t find anything for a 2003.
You're definitely in the minority. The general consensus in the tdi/gti/audi community is that the dieselgeek sigma shortshifters are the best available. I have a feeling the one you had must have been poorly adjusted.This is what I used on my 03 wagon. Loved it. I tried the DG version on our JSW and ended up replacing it with an OEM S3 shifter. I am in the minority, but I just found it too notchy and aggressive. I don't have a desire to reduce the side to side throws.
https://www.idparts.com/vw-short-shifter-8n0711046-p-551.html
ECS is a business like any other. Don't fault them; just comparison shop. Sometimes they are cheaper than other suppliers, sometimes it's someone else.https://www.idparts.com/vw-short-shifter-8n0711046-p-551.html
If you decide to go the Audi TT route (which is what I had on my 2003 as well - also back when they were $45 new) then you can still get one for $60 from one of the forum supporting vendors. Crazy that ECS wants $100 for it.
I have an Audi TT short shifter in my 03'Can anyone tell me what short shifter kit will fit a 2003 VW TDI Jetta Wagon? I already checked dieselgeek.com and can’t find anything for a 2003.
on the 0A6 I cut up the arm and rewelded it with a shorter radius between the axises of the shift rod and the linkage pointAny ideas for a short shifter on a MK5 6 speed
