JFettig
1700F is 926c, The turbo is designed to handle more than that, the tune is designed to limit EGTs to that.
No issues at all with the DSG. I hope it stays like that!Any issues with Stage 3 and DSG?
Do you have 2Micron HPFP protection kits on?
Sig is updated. GL with the turbo!Thanks. Your sig states 2 Micron hence why I asked.
I just paid for the turbo yesterday. I have both of Andrews kits but the pure flow will come off until Andrew has high flow version working...
So you're still hitting the EGT limiter with CR170 turbo and S3 IC?
Im going to assume your EGT's are high because of the injection duration...
Once the community gets the fueling upgrades finished.. this should be a reduced issue....
I will only say yes most likely this is a case. I will leave all other stuff to other treads.Im going to assume your EGT's are high because of the injection duration...
I'm running a 3inch exhaust from turbo to axle back without issues and have the stock turboHey guys, read this entire thread today. I have a stage 2 dpf delete golf and spoke with Andrew today about the 170 turbo.. he guided me to this thread. I ordered darksides egr delete today, and am waiting for the turbos to become a little more availble before upgrading... am I good with my current exhaust system? I currently run RAWTEK downpipe 3" to a 2.5" midpipe and catback... totally straight piped... Would upgrading to a full 3" hurt? I have heard others talk about boost fluctuation issues with the 140 turbo and a full 3". I assume it will work better with a 170.
Anyway, thank you all for your information. I also have that neuspeed turbo damper delete pipe on my car as well. Will that work with the 170 turbo and TIP?
Thanks to all and hope to see some of you at sowo!
The neuspeed turbo damper will work if the turbo is the correct version. The euro cars use the same damper as the US cars and they have the same plastic and metal versions.... earlier part numbers of the CR170 turbo will still have a flat flange which means it uses the metal damper, later versions have the protrusion for the plastic damper. The later ones are the correct ones for the neuspeed damper.thanks guys... just what i heard.. i never had any issue with it fluctuating either.
anybody know if the neuspeed turbo damper will fit?
Thank you!The neuspeed turbo damper will work if the turbo is the correct version. The euro cars use the same damper as the US cars and they have the same plastic and metal versions.... earlier part numbers of the CR170 turbo will still have a flat flange which means it uses the metal damper, later versions have the protrusion for the plastic damper. The later ones are the correct ones for the neuspeed damper.
So the 2.5 option would be too restrictive with the bigger Cr 170 turbo?If you are looking at doing upgrades down the road, I would go with a 3". I'm pretty sure that dieseldubs and buzzken both offer a 3" option. Rawtek only offers the 3" however.
