Old September 9th, 2018, 19:44   #18781
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Wow - This thread used to be bumped several times a day. Guess things have slowed down around here a bit...
What I did this weekend:
- Timing belt and associated components
- Air Filter
- Oil Filter & Oil Change
- Transmission oil change, using GM Synchromesh
- Did some logging for tune updates
- New A/C Condenser
Last weekend
- Front wheel bearings
- Front brake pads
- Finished FMIC install
Weekend before that
- New hitch built and installed
Hopefully good for another 100k (currently at 272k)
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old September 12th, 2018, 19:56   #18782
garreth5
TDI(s): jetta
I just installed my new nexen tires and cleaned the brake pads. Tomorrow I will do the timing belt and change the oil and plugs.
garreth5 is offline   Reply With Quote
Old September 13th, 2018, 10:53   #18783
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
It's that Dieselgate thing and the move for some members to electric (and other) cars.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old September 13th, 2018, 11:28   #18784
romad
romad's Avatar
Put this on the GSW (shameless plug )
So Massachusetts doesn't care if the state is covered?
The fleet:
romad is offline   Reply With Quote
Old September 13th, 2018, 11:37   #18785
We had some debate about this. It's not clear what states care about this. I haven't had a problem so far, don't expect to.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old September 13th, 2018, 14:14   #18786
romad
romad's Avatar
As of 1 Jan 2009, in AZ it is illegal to obscure "ARIZONA":
"A person shall display all license plates as required by subsection A until their lawful use expires or is canceled or revoked. A person shall maintain each license plate so it is clearly legible and so that the name of this state at the top of the license plate is not obscured."
The fine is $135 PLUS "court fees".
The fleet:
Old September 14th, 2018, 07:39   #18787
Powder Hound
Powder Hound's Avatar
I've been chasing a coolant leak for a good long time. I couldn't find the source of the leak and was pretty much resigned to replacing the heater core, mostly due to not finding the source and smelling coolant when running the heater last winter. But, knowing the PIA that tearing the dash apart completely is pushed me to go for the immediate payoff: procrastinate!!
The leak has been getting worse and finally I had to do something since I couldn't go 10 minutes without seeing the low coolant warning on the dash. Not good. I worked harder and decided it was the hard pipe junction into the block - you know, the secret engineering screw-the-pooch solution of simply pressing the pipe into the block behind the alternator with a crummy o-ring where you can't get to it without an hour of skinning your knuckles. And that is only if you already have practiced a lot.
To make a long story short, I re-did the joint once (did it once before, about 10 years ago) but the leak was just as bad, re-did it AGAIN, and the leak was just as bad. After careful examination and failing to find any evidence that it was that junction, and searching, I finally decided it was the coolant recovery tank lower hose to that hard pipe.
After 2 weeks and no coolant loss after the first run cycle, it think I can finally declare victory, and I didn't even have to replace the heater core. (And saved myself a meltdown if I went through all that and it wouldn't have worked!)
Yay!!!
This is all on my 4-dr, and now it is on to the a/c in my wife's NB.
Cheers,
PH
Old September 18th, 2018, 11:22   #18788
falk_ben
falk_ben's Avatar
TDI(s): 2007 GT 170
Fuel Economy: 35-38 mpg
Cool Nighteye 160 watt h4 9006 fogs fitted
Fitted this evening. Smart, modern upgrade to the originals. 160 watt should brighten up the dark lanes.
H4 fitment in the GTI bumper. You need to trim with a stanley knife the plastic mounting flange, to allow clearance on the intigrated cooling pack at the rear of the bulb unit
Golf GTD 257.5 BHP/466 Ft Lbs
falk_ben is offline   Reply With Quote
Old September 28th, 2018, 05:19   #18789
Powder Hound
The coolant leak is still doing fine. Yay!
So yesterday I repaired the downpipe on my wife's '03 1.8t Jetta (yeah, yeah, but the thread title is 'What did you do to your car today?' not what did you do to your tdi today). My welding job was just horrible, so no photos. It didn't help that I didn't have the correct wire and couldn't find it, so I used the flux core that I already had. And I also found out (at the end, unfortunately) that it really helps to use my reading glasses under the helmet.
Anyway, I'll be fighting mosquitoes and to re-install the pipe tomorrow as it is raining today.
More to come in the next couple of weeks while I scramble to get some stuff done before the cold makes it undesirable to spend any more time outside than is absolutely necessary. Maybe I'll have photos on one of my strange projects.
Cheers,
PH
Old October 1st, 2018, 10:19   #18790
csstevej
Well at 404,xxx miles I was starting to loose coolant, I thought it was the coolant bottle as it was leaking out the over flow.
Patted myself on the back , replaced the bowl and trucked on only to have the low coolant light illuminate 3 days later....... sure enough bowl was empty.
Refilled bowl and started to keep track.
It got to the point that I was adding 1 qt every other day with it blowing out the over flow.
Suspected blown head gasket, car doesn't over heat, all temps in normal parameters, I use scan gauge II to monitor my parameters.
Soooo I bite the bullet , get a used head from DAP, new head gasket, bolts , high mileage TB kit and the dreaded hard coolant pipe that is severely rusted, painted but still rusted.
I was surprised that when I pulled the head I still have the original cross hatch marks from when it was built.
I did have oil on top of #4 piston, I suspect this was giving me my smoke on first startup in the morning, wasn't burning oil per say.
The hard coolant pipe wasn't as bad as I feared , maybe because the head was off, but damn!!! That oring does not want to let go easily.
So,all back together no more smoke on start up, I now have 4 working glow plugs , as on the old head I snapped one over 12 years ago.
No more coolant lose and still runs like a raped ape. Malone stage 3 with sprint 520's��
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old October 5th, 2018, 17:55   #18791
dogdots
dogdots's Avatar
TDI(s): None
I dug pieces of a Golf out of my Powerstroke...Neighbor 1/2 mile up the hill didn't set the E-brake and his Golf rolled in a perfectly straight line right into the back of my truck. Cop working the accident said in 16 years this was the first crash he worked that didn't involve any participants
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old October 7th, 2018, 14:35   #18792
red16vdub
red16vdub's Avatar
Yikes
Definitely the true definition of ghost rider.
Bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old October 7th, 2018, 18:51   #18793
Fix_Until_Broke
Noticed that the front tires I put on this spring are worn to junk already .
Decided to check toe with a tape measure - was more than a bit surprised to find that it was over 1" off (toe out).
Called the alignment guy, and he was willing to do it right away on Saturday afternoon. Only thing we could figure was that it was a combination of hitting something over the winter and when I put wheel bearings in a month or so ago, I must not have gotten the ball joints back in the same spot throwing the toe off.
Will run these tires until I put the winters on and then get a new set for the front in the spring. That's a $350 mistake (between the tires and alignment).
I was surprised, the wheel was straight, didn't pull one way or the other, etc - only thing I noticed was that it would push in corners more than it used to and was worse when it was wet, but otherwise drove fine.
Old October 16th, 2018, 08:02   #18794
oldpoopie
oldpoopie's Avatar
Today in my '04 jetta I've been fixing up
....was driving to work and couldn't get 3rd gear.....
tried 4th, good
tried 5th, got it but difficult
went back to 3rd, no go
slowed down and tried 2nd.... good
down to 1st, got it but difficult
back up to 3rd.... no go...
growing frustrated I tried forcing it repeatedly... just wouldn't go.....
Then I looked down and an apple I had on the console had rolled down between the shifter and the edge of the boot... I was smashing the apple..... Removed and shifts just fine. LOL
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old October 16th, 2018, 08:25   #18795
romad
romad's Avatar
tried 4th, good
So an apple a day keeps the shifts awry!
The fleet:
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Page generated in 0.30949 seconds with 10 queries
[Output: 141.09 Kb. compressed to 119.08 Kb. by saving 22.01 Kb. (15.60%)]
