Picked this car (2002) up for free from a pissed off TDI owner
Anyhow, here's some background. PO lent out his car to a friend who ended up putting half a tank of gasoline into it . Car was then driven for a few days before the mistake was discovered. They emptied the tank and refilled it with diesel - nothing was flushed or replaced. It is my understanding he drove it for a few days after with only slight misfires, then the following week he had a crank no start condition.
Here's a video of the engine cranking. I have zero experience with diesel engines, but too me the engine does not sound healthy (metallic clunk)
https://youtu.be/dTT8vTGSQU0
VCDS pulled these codes:
Monday,19,June,2017,21:06:42:53125
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: 3VWSP69M72M030655 License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSP69M72M030655 Mileage: 341140km-211974miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G000AG 4102
Coding: 00001
Shop #: WSC 00066
VCID: 57B790D6B5C2E1F9F8-4A9C
3VWSP69M72M030655 VWZ7Z0A3977939
5 Faults Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 35-10 - Electrical Fault - Intermittent
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 35-10 - Electrical Fault - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16687 - Cylinder 3
P0303 - 35-00 - Misfire Detected
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
Readiness: 1 2 0 0 0
I replaced to two faulty glow plugs and confirmed that the glow plug wiring is good
Other checks:
I have a faulty Lift pump - does not operate with 12V applied to it
ASV works correctly
Fuel shut off valve gets 12V with key turned on
Glow Plug light illuminates with key on ( Relay 109 good)
No fuel obstructions at fuel filter. My mity-vac had no problems pulling fuel from the tank
No serious soot blockage at the EGR
So I'm leaning towards a fuel issue for this NSC.
Would a non functioning lift pump cause a no start for these AHL engines? I am also wondering when the tank was emptied, air might have been trapped/introduced into the lines when the diesel was pored back in = no start. Would gasoline have damage my injection pump?
Thoughts/ suggestions welcome
www.Ross-Tech.com
75 76
Coding: 00001
Shop #: WSC 00066
5 Faults Found:
P0300 - 35-00 -
16687 - Cylinder 3
16688 - Cylinder 4
Other checks:
ASV works correctly
