banshee365
Hey fellas. I've seen this issue on two BRM's now. This one is mine. I bought an '06 early this year. I replaced the cam and timing belt along with a few other maintenance items that are common areas. I've seen this issue once before on a BRM that I worked on before it was wrecked. I was never able to figure out what is causing it but I'd really like to now since this is an every day car.
When you start the car hot it stumbles during the start. You have to hold the key through a couple stumbles and it fires up. When it's cold it starts very nice and smooth. I have the torsion set at -0.5. The injector balance is very good for the miles and I have no engine codes stored. Everything is 100% factory. No tune, no aftermarket injectors, etc...
It almost acts like it's starving for fuel in one or more of the cylinders during hot/warm starts. Cold starts are GREAT as I said. If you were to let off the key as soon as you heard it fire, like you would most cars, it would die on it's face right NOW and you'd have to attempt another start. If you hold the starter engaged through this process it starts right up and idles perfectly immediately after. It's really weird.
A video is worth a thousand words, so I uploaded a video to youtube of what it does. I've see it stumble 3-4 times like this during a start.
Any ideas? I really don't want to throw any parts at it as I like to properly diagnose things rather than firing the parts cannon at it and wasting money. I thought perhaps the a couple of the glowplugs were weak but wouldn't it start bad cold too? If it is glow plugs perhaps the heat after running makes a couple of them work poorly. The glow plug harness was replaced at the dealer by the previous owner not long ago but I think the plugs are original.
https://youtu.be/wD7B3aiITzg
