I take the opportunity to post a full autoscan dump
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 019 DS
Component: 1,9l R4 EDC G000AG 1348
Coding: 00001
Shop #: WSC 00028
1 Fault Found:
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-10 - - - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 3B0 927 156 S
Component: AG5 01V 1.9l-PD RdW 1416
Coding: 00103
Shop #: WSC 12345
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04257
Shop #: WSC 00011
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 00028
2 Faults Found:
00792 - A/C Pressure Switch (F129)
01198 - Comfort Data Bus: Incorrect Software Version
35-00 - -
Address 16 -------------------------------------------------------
Controller: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 00028
Address 17 -------------------------------------------------------
Controller: 3B0 920 849 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 21115
Shop #: WSC 00000
WVWZZZ3BZ4P092831
4 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to B+
01176 - Key
65-10 - Unauthorized - Intermittent
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01321 - Control Module for Airbags (J234)
49-00 - No Communications
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
2 Faults Found:
01332 - Door Control Module: Passenger Side (J387)
Address 36 -------------------------------------------------------
Controller: 3B1 959 760 D
Component: Sitzverstellung 0101
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
01008 - Note: Emergency OFF Switch is Active!
000 - -
01010 - Sensor for Driver's Seat Recline (G219)
011 - Open Circuit
004 - No Signal/Communication
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 03 Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 00028
1 Fault Found:
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 E
Component: Radio BNO 0005
Coding: 04403
Shop #: WSC 00028
2 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
00853 - Loudspeaker(s): Rear
End -------------------------------------------------------
