StingrayRT said:
It has nothing to do with efficiency it is a question of prestige.......long time ago has not to be a good diesel turbos with PR higher than 3 but now both garrett and borg warner make a new designed single turbos capable to handle PR ratio 5 without problems. Both design of vanes has been changed.....do you know that a second generations of Garrett GT30V, GT35V is a real?
I am aware that new generations of turbochargers are increasing the maximum capable PRs. The latest 2.0L 140 PS TDI is actually using a smaller GT1646V turbo than previously less-powerful, smaller-displacement 1.9 TDIs, and the B-W KP39 is considerably smaller than the Garrett counterpart while installed in engines with similar power output. The 170 PS TDI is using the same frame-size GTB1749VM as the VNT-17 everyone is familiar with. 170 OEM horsepower would have been thought impossible with such a small turbo even recently. All these applications are operating at higher boost pressures than ever. The point here is not to disagree with you about the point of the increasing trend and capability of new generation turbos, but rather to confirm it.
But you seem to have access to information about turbochargers that are not out in the general market; the maps I have seen show compressors capable a PR of upto about 3.5, and these only in very large turbos. If you have maps showing otherwise, then please share.
Furthermore, as turbochargers get larger, these high PR numbers are generated only at high mass flow rates, beyond what most TDIs can take in, even when running at PR=3 at 4500 RPM, which is something I've been trying to explain for years. It has EVERYTHING to do with efficiency because efficiency is not just one fixed number for a given turbo, but varies with PR and mass flow. If you oversize the compressor, even if you clear the surge limit at the top-end, it will be less efficient (and therefore more charge heating and greater turbine work) than if the compressor were operating at its sweet spot (see red point in map below).
Like I said in another thread, the reason for staged-twin turbos, as far as the OEMs are concerned, is to eliminate the compromise between the desirability of a large turbo for top-end performance, and the boost threshold and turbo lag at the low-end. Every implementation of staged-turbocharging has the big turbo working alone at the top-end. If you don't care about the low-end, you don't need two turbos but just one big one.
