My 2010 Jetta has about 95k on the clock, and I'm hoping to get another 5k out of it before the buyback. But I recently it threw the below code:
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 22142 444 94218
VCID: 78D11FE90B4853858D-802C
1 Fault Found:
008817 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 - 000 - too Rich - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 152748 km
Time Indication: 0
Date: 2025.14.27
Time: 08:39:59
Freeze Frame:
RPM: 1771 /min
Speed: 91.0 km/h
Lambda: 42.6 %
Mass Air / Rev.: 530.0 mg/str
Voltage: 0.075 V
(no units): -1.27
Voltage: 0.975 V
Readiness: 1 1 0 0 0
I looked this up online and it seems like the post-cat sensor went bad. Some shops around me are quoting around $300-350 to replace the sensor. Does that sound about right? It it possible to run on the bad sensor for another 5-6k?
Coding: 0050078
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 152748 km
Time Indication: 0
Date: 2025.14.27
Time: 08:39:59
Freeze Frame:
RPM: 1771 /min
Speed: 91.0 km/h
Lambda: 42.6 %
Voltage: 0.075 V
(no units): -1.27
Voltage: 0.975 V
