VTJC
Hi, As I was driving home all of a sudden with our warning or cause my High Beams went off. So I slowed down and flicked to low beams which still work! A further inspection reveals that the High Beam fuses are fine and they actually come on when I pull back on the high/low switch, so I can deduct that the bulbs and wiring is okay. Did I fry a relay or something? Any thoughts would be appreciated. I did put in a pair of E-Codes with low wattage H4’s about a month ago.
Thanks in advance, Jamie
