PRY4SNO
Had a new issue cause limp mode driving normally in traffic two days ago.
Flashed the ESP light and wouldn't gain revs at all. Pulled over, cycled the ignition and it was just fine.
Cleared codes, new persistent code comes up all the time now:
P0607 - Control Module Performance Open circuit/short circuit to B+
Intermittent
I pulled the fuse and it was fine, cleaned the contacts, light dab of dialectric tune up grease and reinstalled.
After some searching seems like older TDIs had weak 109 relays but not so much with these new CR diesels.
Trying my best to get the car into VW for the emissions recall so want to get this tidied up quick as possible. Have access to VCDS from a friend so if there are any specific measuring blocks or scans I can post to help please LMK!!
Car is a 2010 GSW TDI with a CJAA and 6MT.
Thanks!!
Intermittent
Thanks!!
