chittychittybangbang said:
But a clutch should last the life of the car in normal daily driving, like the previous posters said, there is too much to effect the lifespan to guess. The most preventative maintenance I would do is to replace the clutch master and clutch slave cylinder. These wear out due to time and corrosion and they are cheap and easy to replace.
Actually, I'm not sure about that "cheap and easy" part. I would have to look up in the Bentley whether it's the master cylinder or the slave cylinder, but I know one of them can't be replaced without removing the transmission.
Brandon7: a clutch failure, from whatever cause, is not a major problem. The popular replacement kit is the G60/VR6 package, an upgrade good for up to 300 ft/lb of torque -- or about double that of the stock TDI engine.
Not only does a 2003 Jetta TDI have "some" value, it is perhaps the second-best car you can own.... second only to a 2003 Golf TDI. 133k miles is just barely broken in -- with continued good maintenance practices, your TDI will last you another 500k miles. Yes, it will need some new parts, now and then. But the engine, transmission, and most other parts last a good long time. I don't know of any other car that is more resistant to rust and corrosion.
