Cat38
Hi all, been checking through the forums here for a while but I can't see anything here that seems to relate exactly to my symptoms.
I just bought an 03 Jetta ALH with an automatic transmission and I drive mostly around town with the occasional short highway trip and I never get more than 650 km to a tank (I think this works out to roughly 30mpg if my calculations are correct). I've talked to others with similar cars who are getting around 900kms/tank (about 42mpg).
Here's what I've done so far:
- replaced the air and fuel filters (this car doesn't have a snow screen)
- cleaned the MAF sensor
- cleaned the intake manifold and EGR (it was pretty coked up)
- increased the air pressure in the tires to just below max
I have no fault codes and the car seems to have some power (I dan't really have a good point of reference for this though as my last car was an 87 Jetta TD!). The exhaust is fairly normal too, not much soot.
I have a VAG-COM cable and have had a look at the specified vs actual manifold pressures in VCDS and they seem to be pretty close to each other. Does this preclude any possible problems with the turbo/guide vane system or a potential plugged cat converter?
Another interesting thing is that on a recent long highway trip I got about 500kms on half a tank (about 47mpg or so) which is more consistant with the fuel economy I was expecting. This was on cruise control on the I5 doing about 110km/hr the whole time.
Am I correct in assuming that I should be seeing around at least 35-40mpg around town?
Any help would be greatly appreciated gentlemen!
