its not the end of the world. ill take my chances. what I am not doing is:
1. replacing it myself on the street
or
2. having it towed hundreds of km for the nearest competent guy to fix it.
anyways, I talked with my brother about how many times he turned it over the week prior, he confirmed it went a few times so I knew it wasnt seized. he was eager to see it run and kepy hounding me to start it up and eventually told me "if the timing belt breaks ill give you $2000 cash for it right now" so...
I threw the battery in, made sure the fans had no snow around them and spun freely and turned the key.... it literally started up INSTANTLY. ZERO delay, I swear the key barely got fully turned and the engine was already purring nicely... 2 year old diesel and snow packed motor as shown in post 33 and all.
my 04 when fully warm doesnt even start that smoothly and instantly.. takes literally 1 full second of needing the key turned in the 04 BEW. this 03 ALH starts so quick, its impressive.
let it idle for 20 or so minutes, then took it on a drive around town. it ran for about an hour so far total, and I put 15 km on it, even took it on the highway where I discovered its first problem, otherwise it runs very very good, feels super tight compared to my 04 with 110,000 more km on it. (215 VS 325). im impressed. I like it already.
feels like it has a flat spot on the front driver tire (but it doesnt). it has a hell of a vibration and a weird clunking sound from that front corner. im going to get tires balanced tomorrow, do an oil change this week and then fully detail it this weekend.
ordering a timing belt kit from roseland right now with every option available, as well as the serp belt assembly too with all options, then she goes to a mechanic for a full service, skid plate, EGR delete, Jeff Stevenson tune, ventectomy, cam and lifters checked, new thermostat, time the injection pump, and intake decarb.
then a frostheater this summer, swap my hitch from the BEW over, glass headlight lenses, and possibly swap my seat from the 04 BEW over too as the 03 ALH has a rip in the drivers seat.... is this possible? is this an easy job?
